Garage (pics) *update 2/8/10*
Old Dec 11, 2008 | 07:20 AM
Jonesi's Avatar
Nothing crazy but thought I'd share.. I had to relocate the water line so I still have touching up to do and plan on painting the workbench.. And a few other things but here it is.. Came out pretty good for what I had to work with in the small one car garage. The bench is obviously screwed into the studs and is solid as a rock.
Old Dec 11, 2008 | 07:30 AM
Jonesi's Avatar
UPDATE: 10/12/2209
Finished product:
Painted a brown acrylic deck stain paint. I really like it, it came out Really good.. Added some electric outlets. Added the light above the workbench. And of course the TV
Old Dec 11, 2008 | 08:01 AM
pmptx's Avatar
Honda+Blue=My garage
Looks great.
What is the depth, as that looks thin, but it may be needed to have room for an actual car in a garage?
Old Dec 11, 2008 | 08:05 AM
Jonesi's Avatar
Exactly.. It's only 15" inches deep.. You can see the nose of my car in the last pic.. Best I could do and still have room for the car. Especially if I ever sell the place..
Old Dec 11, 2008 | 01:22 PM
svtmike's Avatar
Interesting door construction. I take it the panels are just glued into the rabbet on the back of the frame? Did you use kiln dried lumber for the door frames or is that stud grade lumber?
Old Dec 11, 2008 | 02:16 PM
Jonesi's Avatar
Nope just plywood.. Glued and nailed into the frame..
Originally Posted by moeronn
Did you actually make the doors? That's pretty impressive, regardless.
Yea, router and I tried out this like pocket hole jig, only two slots instead of one.. Worked great..
Originally Posted by Bearcat94
What's the bench top made of?
(I can't quite tell if it's Butcher Block. If so, how much did that cost? I inquired about Butcher Block and it was CRAZY expensive).
No, it's not Butcher Block. I bought almost everything the cheapest I could since it's not furniture and it's a workbench that will be battered and bruised anyways.. It was a PITA sorting through the inventory to find straight and true pieces but I saved a ton of money doing so..
Old Dec 11, 2008 | 02:25 PM
svtmike's Avatar
What are the door frames made from? Reason I'm asking is if it's stud grade pine you can expect some shrinkage.
Old Dec 11, 2008 | 02:39 PM
Jonesi's Avatar
If only I could remember.. Some just 6' junk that I planed and cut down to what I needed. It was like $1.88..
The desk I made previously was done with almost everything high grade.. The workbench.. Not so much..
Old Dec 11, 2008 | 09:25 PM
Jonesi's Avatar
Originally Posted by NSXNEXT
Nice work with the pocket screws in the doors. I gotta get one of them.
You can't believe how nice and easy it is. I highly recommend it.. Just buy it online somewhere ahead of time. They are around $100 in stores..
Suggestion....if I were doing it I would get a piece of 1/4 plywood and glue a piece of formica to it. Then screw that down to the top. It'll provide an extremely durable surface to deal with the spills, cuts, dings. And when it starts to look like crap, unscrew it and make a new top.
excellent idea..!
Old Dec 12, 2008 | 07:27 AM
Jonesi's Avatar
Jonesi, if I ever win the lottery, I'm flying you down to Jacksonville to make shit for me. Custom garage workbench, bar, etc.
To be honest it's more about tools. If you have the right tools you can make and apply them to anything. I'm just lucky to have access to my Dads shop. Plus he's a woodworking fool..
Sounds like stud grade! Well, if they do funny things as the wood dries it won't be tough to make new ones.
Yea, I'm not too concerned about it. It would only take a few minutes to make. I just made a right angle fixture so everything would be square screwed it and glued it, through it on the router then threw the inserts in.
Old Jan 8, 2009 | 04:38 PM
Berner's Avatar
Where are pics of the finished product? Dont leave us hanging here jonesi.
Old Oct 12, 2009 | 12:38 PM
Jonesi's Avatar
Update
Finished product:
Also added a nice little area for yard work tools, etc etc.. I just took a couple boards painted them and screwed them. Now I just add whatever hooks I need as I go. Came out really nice. Looks clean and keeps the tools up off the ground. Berner helped out a lot with this..
Just need to touch up a little bit.. The black screw heads are driving my OCD insane.
Old Feb 8, 2010 | 02:11 PM
Jonesi's Avatar
Another Update 2/8/10
Added a little storage. Forgot to take a before pic but it looked somewhat similar to the left corner in this pic only about three times worse as more stuff accumulated Berner helped out as usual on the project.
The quick and easy build:
Installed:
This is hanging out in the basement:
Running the hose(all needs cleaned and hidden):
Out it comes you can see it in the other pics
Check the other installed pics you can see it there.
Old Feb 8, 2010 | 07:56 PM
svtmike's Avatar
How'd you attach the storage unit to the wall?
Old Feb 8, 2010 | 08:04 PM
Jonesi's Avatar
You can see on the one install pic with the doors open there's several 3" drywall screws into the studs. Probably 8 total. It was already pretty solid once I leveled it up. Just needed to tie it into the wall. It's solid as a rock.
Old Feb 8, 2010 | 08:16 PM
Fibonacci's Avatar
I feel the need...
Nice work Jonesi.
One regret I have is not paying a few extra bucks for a fully insulated garage - dumb move on my part. The upshot is I have one huge beer fridge come hockey season.
Old Feb 8, 2010 | 09:39 PM
svtmike's Avatar
I see them now, I think. Putting them through the sides and (I'm assuming) the plywood back is a bit ... unconventional.
For future projects, you might want to get some 3" cabinet hanging screws. They'll have wide, flat heads so you don't need to countersink them.
Old Feb 9, 2010 | 06:50 AM
Jonesi's Avatar
Good tip and I actually would've used them but it's for the garage I was keeping costs down and trying not to over do it toward the end. The whole build I spent Wayyy too much time on everything when I should've just been roughing it. It's not a stained piece of furniture, it's a painted cabinet in the garage. I'm sure you know what I'm talking about
Old Feb 9, 2010 | 07:23 AM
svtmike's Avatar
I do. I have quite a few painted cabinets in my garage. Luckily I also had a bunch of cabinet hangers left over from when I put up some nice cherry cabinets in my laundry room.
Only potential difficulty I can think of is if the house shifts -- since you have the cabinet tied to two walls it might rack a bit depending on how the walls move.
Old Feb 9, 2010 | 07:44 AM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Man, Jonesi, if I had a garage floor as true and straight as yours, I would tile that sucker!
I just painted mine.
Old Feb 9, 2010 | 08:50 AM
Jonesi's Avatar
I'm not exactly worried about it. I have been saving all the left overs so one day I'll have that stuff laying around from all the different projects. I just have no idea where to put it all or how or what to use to organize it. What do you use? Any tips or ideas?
Old Feb 9, 2010 | 08:54 AM
Jonesi's Avatar
If you look close enough at everything you will see all the shims everywhere.. Wish it was that good.. Although they did do a nice job. I can't complain.
Once summer comes and the concrete warms up I'll be painting mine also. It's probably and hopefully the last thing I will have to do in the garage.
Old Feb 9, 2010 | 09:00 AM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
I think you should tile it. I can help, along with Bigman!
Paint looks great at first, but then it sucks. I've had to repaint mine about 4 times now. Still looks like garbage underneath where the tires on the cars are.
Doesn't matter how long you keep the cars off it, the paint underneath a hot car tire will come up. If I could have done it over, I would have tiled my garage.
Old Feb 9, 2010 | 09:17 AM
Jonesi's Avatar
Is there a easy and reasonable/inexpensive way to tile a garage floor?
Old Feb 9, 2010 | 01:32 PM
svtmike's Avatar
I just have a 5 gallon bucket that I through loose fasteners in. The cabinet hangers came in their own box that I keep on a shelf for a rainy day. My next couple projects are going to be additional storage for my workshop though....
Old Feb 9, 2010 | 02:04 PM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
I didn't say it would be easy. It would be friggin' EPIC though. My garage isn't exactly mountains and valleys, but I would love to do this. HD is selling some tile at 18X18 for $0.68 each. Based on a 20ft.X20ft. double garage (400 sq. ft.), it would cost $168, plus grout and the tile adhesive.
Holy crap, that is cheap. I may do this to my garage. I have to make sure, if I do do this, that the valleys are correctly filled in so the tiles don't crack under the weight of the cars.
Old Feb 10, 2010 | 09:04 AM
hornyleprechaun's Avatar
Bent = #1
Are you talking about ceramic/porcelain tile? I've never seen that in a garage.. googling now..
Old Feb 10, 2010 | 01:36 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Looks great Jonesi, you and Berner should come do mine next
Old Feb 10, 2010 | 01:43 PM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Yep, I've never seen it either. I would assume it's because certain ceramics might not be able to hold up to having a 2400-5000 lb car on them a lot of times.
Old Feb 10, 2010 | 02:11 PM
DarkSithCL's Avatar
Be Strong AND Courageous!
looks awesome... wow!!!!
Old Feb 10, 2010 | 02:12 PM
DarkSithCL's Avatar
...my wife would be so happy if our garage looked 1/4 that good!!!
Old Feb 10, 2010 | 07:16 PM
fsttyms1's Avatar
Looking good. 1 Suggestion on the air hose. Maybe mount a regulator on the wall that the hose attaches to, that way you have some regulation over it? I mounted my compressor in the basement, ran some hard line from the compressor to the garage to a filter and regulator. All i have to do is plug the hoses in adjust the psi and go to town working.
Old Feb 10, 2010 | 08:51 PM
Jonesi's Avatar
Already thought about that.. so far.... everything has been too large and I want the setup to be hidden.. Worst case for now I will be going to basement to adjust the pressure until I figure out something creative to hide that whole setup. Not sure about you but I rarely adjust the pressure so right now it's a not a issue.
Old Feb 10, 2010 | 08:52 PM
Jonesi's Avatar
Old Feb 10, 2010 | 09:34 PM
fsttyms1's Avatar
my tank goes up to 160 psi so i need some adjustment or i blow up my air tools
Old Feb 11, 2010 | 06:33 AM
Jonesi's Avatar
ok..... Not sure about you but I keep mine around 100-120 and leave it there for the most part.. I think everyone keeps it at a reasonable level. I don't have to adjust mine that often that puts this very high on my priority list. Although, it is a nice feature and nice to have.
Old Feb 11, 2010 | 09:41 AM
fsttyms1's Avatar
I paint things often with it so i need to drop the psi down to like 40 at times, its easier to regulate for me.
Old Feb 11, 2010 | 02:06 PM
thunder04's Avatar
Sweet!
I'm not sure about the whole tile idea...wouldn't it be annoying when you need to roll something across the garage...like a jack or if you're on a creeper or something? Unless you go with something that doesn't involve grout lines and can be pretty smooth...I dunno
Old Feb 11, 2010 | 02:09 PM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
No different that rolling it across the kitchen floor.
Old Feb 11, 2010 | 02:24 PM
moeronn's Avatar
is learning to moonwalk i
But how often do you jack up your car and slide under it while your in the kitchen?
