My Weekend Project - Hearth Teardown
Old Oct 14, 2009 | 11:41 AM
  #41
rza49311's Avatar
Originally Posted by jupitersolo
Nice change out, but I would have kept the wood burning stove. I remember so many times with my grandparents and my dad how warm they kept the house in the winter.
My wife hates wood heat. I like it personally but we'll be able to use the gas stove to supplement our heat. I'm going to keep the wood burner and I'd like to put it in my shop but not sure yet.
My neighbor i was talking about is coming over tonight to check it out and hopefully we are going to come up with a solution. I've got all the floor down right now except the last two pieces, one being the piece i have to glue in. I'm waiting on it to see if he can help me with that too.
Old Oct 14, 2009 | 03:43 PM
  #42
jupitersolo's Avatar
nnInn
It does have a smell to it, my grandparents also used coal in theirs. The wood and coal and the cold winter mornings, man those are some great memories.
Old Oct 15, 2009 | 03:13 PM
  #43
rza49311's Avatar
My neighbor had to cancel, now he's coming by Saturday.
A big of good news though, the heater is in and they'll be installing it this next Thursday.
Old Oct 19, 2009 | 09:05 AM
  #44
rza49311's Avatar
Got all the flooring back down and ended up about a 6" gap rather than 7"
Pics and explanation tonight.
Neighbor is starting off by making one 6" trim piece about 1/2" thick with a bevel. We are going to just set it down and look at it, then see what else we need to add.
Old Oct 19, 2009 | 08:23 PM
  #45
rza49311's Avatar
Basically, cut off the end of the one piece of laminate and glued it to another to extend the shortest piece, which made the overall gap 6" instead of 7". then glued in the final small strip.
Here the padding is down and edges taped. ready for laminate to go back in.
Almost done.
the long piece that almost touches the hearth is the one i cut some off and glued to the one on the left which was the shortest piece. Well,actually my neighbor cut it and glued it. You can also see the narrow strip that was the last piece to go in with glue.
Last piece being glued in and pressed with bricks.
All done!
The tiny piece is one of the glued pieces, it came out perfect.
The strip i had to glue and pressed with bricks. If your standing, you don't see it but a closer look reveals its not perfect. In hindsite, I should have flipped a piece of laminate upside down and placed it over the two pieces then applied pressure. I used wax paper to prevent things sticking to the glue.
Now I'm waiting for him to bring me the trim piece for testing. Not sure when he'll be doing it, hopefully this week.
Old Oct 22, 2009 | 12:19 PM
rza49311's Avatar
Just got installed this morning. Still waiting on first trial piece of trim. Definitely gotta replace the blower power cord, not long enough.
Old Oct 22, 2009 | 12:34 PM
hornyleprechaun's Avatar
Bent = #1
Looks nice
Old Oct 22, 2009 | 12:38 PM
  #48
svtmike's Avatar
Like the new stove much better. I take it there's no way to easily hide the cord?
Old Oct 22, 2009 | 12:41 PM
  #49
rza49311's Avatar
Thanks
Yeah, the only thing I can figure to do is, get a longer cord, snake it straight back against the brick, then down the edge of the hearth in the corner, then along where the floor it meets the wall.
Old Oct 22, 2009 | 01:58 PM
  #50
RaviNJCLs's Avatar
Not bad. I think from close you can see the differences, but from far it looks pretty good.
Old Oct 23, 2009 | 10:46 AM
  #51
TBone2004's Avatar
Team Anthracite Member
Is it something that stays plugged in all the time - or is that how you turn it on and off? If always plugged in, then could you run the cord through the wall and directly wire it to the outlet?
Stove looks real nice btw.
Old Oct 23, 2009 | 10:57 AM
  #52
rza49311's Avatar
^^ Thanks We are really happy with the finish and overall look, we were concerned the graphite color wasn't going to be what we wanted. The only thing we wish was the hearth wasn't so tall. It really sits up quite a bit but we agreed it still looks alot better than the old hearth/stove!
It would stay plugged in all the time. I toyed with the notion of hard wiring it, might be the way to go if i can come up with something that looks good.
Old Oct 23, 2009 | 10:43 PM
  #53
SakiGT's Avatar
I think youre nuts for removing that old stove.
Old Nov 5, 2009 | 09:59 AM
  #54
rza49311's Avatar
Got the molding down last week. I put two coats of ipswitch pine stain and two coats of poly. When I was doing it, it looked very much like a close match in the grain. Not quite what i was hoping for but didn't turn out too bad
Still need to get a longer cord for the blower too.
Old Nov 5, 2009 | 10:32 AM
  #55
Bent = #1
I don't like the up close look, but from a distance it looks good
Old Nov 5, 2009 | 10:41 AM
  #56
svtmike's Avatar
That'll get ya by. I'd have done pine so it didn't introduce yet another grain pattern, but I doubt anyone but you will notice.
Congrats on getting it done!
Old Nov 5, 2009 | 10:47 AM
  #57
rza49311's Avatar
Thanks, the project definitely took alot longer than I imagined!
On a side note, I secured it with a battery powered dewalt nail gun that my neighbor had. He warned me about it jamming and sure enough the thing jammed about every 5th nail! Convenient yes but I was not impressed.
Old Nov 5, 2009 | 11:02 AM
  #58
moeronn's Avatar
is learning to moonwalk i
Nice. Not quite a perfect match, but about as good as you can expect. Definitely a big improvement over the brick dance floor sized hearth you had.
Old Nov 9, 2009 | 11:43 AM
  #59
chill_dog's Avatar
Oderint dum metuant.
Looks good...much improved.
Old Mar 5, 2010 | 09:30 AM
  #60
rza49311's Avatar
Bump.
Room is being painted as I type. New rug and curtains as well.
Painting it myself. First time I've painted a room this large. Ceiling is staying white
Pics coming soon.
Old Mar 11, 2010 | 02:44 PM
  #61
rza49311's Avatar
Still waiting on curtains but the walls are done and the rug is down. Blue tape is for spots I had to touch up. what do you think!?!? Don't be too harsh
Before:
After:
Old Mar 11, 2010 | 02:53 PM
  #62
svtmike's Avatar
Looks good!
Old Mar 11, 2010 | 03:04 PM
  #63
rza49311's Avatar
Oh I forgot the best part.....
It would have been done sooner except I had a "little mishap". Ok, so we told our painter what we wanted and he told us it would be a week or two before he could come. That time frame came and went so we decided to tackle it ourselves. Everything was going great, I had taped everything, cut in was done and I was rolling the first coat when it happened. I told my wife to go get me the ladder and you know what happens next. The paint can was up on the ladder. DOWN IT GOES. Half a bucket of paint is on the floor, on the wall, ON A GOOD PORTION THE HEARTH, on the heater, on the gun cabinet, on the old rug, on the sofa and on the window. EVERYWHERE BASICALLY. Thankfully, it was latex paint so we immediately went into cleanup mode. About 2.5 hours later we had 95% of it up. Luckily on a few small places got on the couch and they came out for the most part. Likewise for the rug. The only thing left was the hearth. I had pretty much decided we were going to have it redone but we scrubbed the S#%* out of it with soap,water and my tire cleaning brush. Then after that, we used to Muriatic acid to try and bring some luster back as all the scrubbing and dark paint had dulled it up pretty good. So after scrubbing, scrubbing and scrubbing some more, it ycame out prett decent. You really can't tell from the pic. It was the biggest mess I've ever had to clean up in my life. Thankfully, it was my wife it who spilled it and not me! I'd still be hearing about it!
Old Mar 11, 2010 | 03:30 PM
  #64
svtmike's Avatar
That sucks.
Does the room feel warmer and homier now?
Old Mar 11, 2010 | 03:33 PM
  #65
rza49311's Avatar
Yeah I think so. We are both liking it. Still waiting on the curtains like I said and that'll close it up a bit more too.
Old Mar 23, 2010 | 01:11 PM
  #66
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Wow, that's some dark paint to spill all over, glad you were able to clean it up. Holy cow I'm sure that was a stressful time. Just read through your whole thread, I really like how everything turned out, and I enjoyed reading through your experience. Thanks for sharing.
Old Apr 15, 2010 | 02:44 PM
  #67
rza49311's Avatar
Finally got the curtains about a week ago. Took some pics this morning. Lighting sucked but you get the idea
Before
After
Before
After
Old Apr 15, 2010 | 03:16 PM
  #68
svtmike's Avatar
Nice improvement!
Marcelechka
Home & Garden
188
Sep 11, 2022 11:53 AM
tsx_boy
Dec 13, 2019 08:33 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
mars
Sep 28, 2015 11:03 AM
h22lude
Sep 27, 2015 06:22 PM
