CL: Factory NAV install
Old Oct 28, 2009 | 05:43 PM
H's gray 03 CL type S's Avatar
Factory NAV install
Has anyone ever installed the factory navigation system in a 01-03 CL that didnt have one originally? And if you did was it a huge pain in the ass.
Old Oct 28, 2009 | 08:43 PM
Jonesi's Avatar
Check the DIY/FAQ thread under 2nd gen TL, its very similar and will give you a good idea..
Old Oct 30, 2009 | 12:51 AM
modelcarnut's Avatar
TRAVIESO
too much work involved. You're better off getting an aftermarket dbl din unit.
Old Oct 30, 2009 | 03:10 AM
atrix415's Avatar
Agree to above post.
Get a double-din would be the best. No cutting into wires much compared on changing out the entire dash of your car. Get the metra dd kit and get a double in-dash screen. If you need measurements crutchfield has them. I think the height is 4" inch tall and width is 5-7" screens it fit. Also you might need pac-oem2 if you plan on keeping stock BOSE system.
Old Oct 31, 2009 | 02:21 AM
aznboi2424's Avatar
Just finished my conversion
Old Nov 2, 2009 | 12:35 AM
Flipster23's Avatar
^pics or it didnt happen
Old Nov 2, 2009 | 01:08 AM
richardparker's Avatar
3.7L Nitrous Breathing CL
Is it working properly ?
You must got some time into the install.
I've heard it a PITA to do the conversion.
Old Nov 2, 2009 | 01:50 AM
aznboi2424's Avatar
yea I think it took me about 2-3 weeks total with the install. But I wasnt working on it every day for 8 hours a day. Just read the DIY, most of the answers are in there. Lots of splicing and stripping wires, I bought 2 different wire strippers/crimpers and probably 15 bucks of butt connecters/t-taps/snap connectors. Im pretty okay with wiring, this was my biggest project to date. But its working flawlessly, love it.
lol you saw it in person
Old Nov 2, 2009 | 02:19 PM
andr240's Avatar
I've done this also and i think it comes down to how much you get all the parts for and if you're willing to put in hours of work for outdated technology that in my opinion looks nicer than any cheaper aftermarket NAV. The best way i can describe my own experience is since i've done it i like it in my car, but i wouldn't do it again. I got all my parts for right around $350 from a junkyard and did all the work myself. Like someone else already said, be ready for A LOT of wiring, splicing, tapping, and soldering(up to you). Good luck whichever way you decide and let me know if you have any questions i might be able to help with.
Old Nov 4, 2009 | 06:39 PM
OLD_HATCH's Avatar
Agree with the previous post.
Rather old tech but in the end its worth more than a window gps or expensive headunit that could get stolen.
Be prepared to find shielded wires and get complete wiring diagrams for your car.
Old Nov 4, 2009 | 06:56 PM
aznboi2424's Avatar
I was kinda sketchy with the shielded wires. I had all the wires from the DVD unit to the driver's fuse box, so it was kinda easy to shield those wires but it still had gaps from where I cut the wiring. From the fuse box to the navi, those are unshielded. I dont have any problems, voice and screen is clear, no fuzziness or sketchiness.
I will be returning the shielded wiring I bought from frys.
Old Nov 18, 2009 | 03:10 AM
-Vip3r-'s Avatar
ABPUA5
ok dudes, i did my conversion last year in december, and it was a success.. but now i've been running into a problem.. for some reason, whenever taking slightly hard turns.. or randomly hitting brake.. or just straight up just driving on a flat road no bumps, my screen decides to go black, sometimes resetting with the acura screen coming up.. sometimes it just starts spazzing out completely and keeps resetting (so it seems, keeeps going black, turning on, going blackk..) have no idea what the problem could be.. i know somethings loose or not getting contact, but what do you guys think it is? thanks!
Old Nov 18, 2009 | 01:37 PM
Jonesi's Avatar
I think you nailed it..but... as we all know intermittent problems suck. Time to get a volt meter out and start checking continuity.
Old Nov 18, 2009 | 05:11 PM
OLD_HATCH's Avatar
That and there is a diagnostic menu built in that will run some tests. Might be able to pin it down that way too.
You hold 3 of the buttons down at the same time for 5 seconds and it will go into a diagnostic menu. Forget which 3 though off the top of my head.
Old Nov 18, 2009 | 10:46 PM
aznboi2424's Avatar
anyone know the combo or how to get to the menu? I read some thread and they seem to say menu + cancel + map/guide but it doesnt work for me.
sounds like loose power or loose ground wire. one of the biggest scares for me after i completed the project.
Old Nov 27, 2009 | 04:04 PM
5thgen's Avatar
Trust Me I'm Better!
To get to the diagnostic menu:
Turn key to II
Press OK on NAV screen when it appears
Hold down Menu, Map/Guide, Cancel in that order for 5 seconds
Diagnostic menu should appear.
Old Nov 27, 2009 | 10:37 PM
aznboi2424's Avatar
okay, thanks. I pressed it in the wrong combo, I didnt know there was a specific order.
Old Dec 2, 2009 | 05:20 AM
AIRWOLF3's Avatar
PIc pic oic pic pic please!
Old Dec 2, 2009 | 11:59 AM
aznboi2424's Avatar
just looks like a stock CL with navi now theres pics around. mine is nothing special
Old Dec 18, 2009 | 10:51 PM
tl_2003's Avatar
6th Gear
Have you guys ever experienced your outside temperature gauge readout not working? I took it to Acura dealer and they told me it was the control printed board and its was almost $588 to replace it. If you know what i'm talking about and know what part it is could you tell me where i can get one. Thank you for your time.
Old Dec 19, 2009 | 02:28 AM
aznboi2424's Avatar
yea. mine was ---. The sensor is in the front of the car, near the lever for the hood latch, in front of the radiator and next to the horn. It looks like a nub with a harness and 2 wires. My problems was that the wires were severed in my case, not sure about yours but this isnt navi related.
Soul_Deamon
Nov 13, 2018 04:44 PM
scionxb3003
Oct 2, 2015 05:50 PM
mgbe11
1/2G MDX (2001-2013)
Sep 15, 2015 07:53 PM
siularbar
Sep 11, 2015 10:40 AM
asahrts
Sep 4, 2015 05:55 PM
