| Welcome to Acurazine.com! |
Welcome to Acurazine.com. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Acurazine.com community today! |
Thread Tools |
#1 | |||||
Mega Moderator
2003 Mitsubishi Lancer Evolution |
Navigation voice no longer works
__________________
2004 NBP Acura MDX Touring NAV RES 3000k Yellow HID Fireup (MDX) http://ca.youtube.com/watch?v=c0fJFTe9vu0 "There is always a light at the end of the tunnel, but sometimes its a train" -Sir Charles Last edited by FiftyFive; 11-02-2009 at 4:30 PM. |
| Sponsored Links | ||
#2 |
Registered User
The nav unit sends the audio signal to the headunit along with a mute signal.
This total 3 wires. If these 3 wires are in tact and are not loose anywhere then it could be a problem with either the nave unit or radio. I'd be leaning more towards wiring problem or maybe nav unit though. No other crackling noises coming from stereo correct? If you have uninstalled or messed with any wiring in either the trunk near the nav unit or the headunit you might have slightly pulled one of the audio cables from either. Anything like that recently before it started the crackling or around the same time? |
#3 |
Mega Moderator
Well I do have a system in the back but it is tapping the factory sub and nothing was touched behind the headunit or nav unit (which is located under the front passenger seat).
I've had the system for over a year and this just happened recently. Stereo sounds fine. I did notice a slight crackle in the navigation voice a few weeks ago and from there it gradually got worse and now is completely out, just crackles. Think that could be the wire becoming loose due to the bass of the system? ![]()
__________________
2004 NBP Acura MDX Touring NAV RES 3000k Yellow HID Fireup (MDX) http://ca.youtube.com/watch?v=c0fJFTe9vu0 "There is always a light at the end of the tunnel, but sometimes its a train" -Sir Charles |
#4 |
Registered User
check the plugs at the nav unit under the seat to make sure they are all in correctly and the wiring is not pulled out of the plugs.
maybe someone kicked something or shoved tsomething under the seat crackling that progressively got worse definitely sounds like a wiring problem though. |
#5 |
Got your mom in
2003 Acura TL Type-S |
it means she wants to break up with you so she doesnt want to say anything to lead you on
__________________
Im so JDM that my blood is Type-R Ban jjashaa Again!!!!!!! |
#6 | |
Mega Moderator
Quote:
__________________
| Tags |
| acura, crackling, honda, navigation, voice |
| Thread Tools | |
