| Welcome to Acurazine.com! |
Welcome to Acurazine.com. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Acurazine.com community today! |
Thread Tools |
#1 | |||||
Registered User
| Sponsored Links | ||
#2 |
Registered User
2001 Acura CL |
I would check your grounds,make sure your grounding to bare metal.Did you try differnt rca's ? Then turn the levels down on the loc.
#3 |
Registered User
You could be experiencing feedback. What happens is the sub produces pressure in the trunk which moves the rear speakers which produces a signal that is sent to the sub. I've also seen this happen when closing a door. Try getting the signal from the front speakers and see if the problem goes away.
#4 |
Registered User
i already tried changing the rca wire and my ground source i noticed that the rublimg changes with my rpms since it only rumbles when the engine is running once i get past 2000 rpm the rumbling stops and if i disconect the rca wires from the output cinverter it stops so it must be sumthing with the cars factory audio system im guessing
#5 |
Registered User
2001 Acura CL |
sounds like you have a power wire laying on top of your speaker wires going to the converter,or a striped speaker wire conducting with the body,or loc is just junk
#6 |
Registered User
i already changed the loc but il check my wires again
#7 |
Registered User
i also noticed the rumbling will stop if i open one off my doors or open the trunk
#8 |
Registered User
2001 Acura CL |
Thats odd
| Tags |
| acura, rumbling, tl |
| Thread Tools | |
