9006 super white LED Bulb for foglight !!!!
Guys,
I am still taking order. They are $50 a pair shipped.
Each bulb is clustered with five high power super
white 8mm LEDs and two 3 watt metal oxide power
resistor s to drive and protect the LEDs. The life expectancy of this LED is 100,000 hours or about 11 years under normal operating condition. You will never have to replace your foglight bulb ever again with this bulb. The bulb is a direct replacement of a regular 9006/HB4 halogen bulb. It is plug and play bulb. There is no need to modify your existing foglight housing.
Keep in mind that the bulb is to make your foglight
look cool and attract attention when you are driving at night or
daytime. The bulb will not illuminating the road as good as your
standard 9006/HB4. If you don't need your foglight to illuminate the road and just want to have that super white light output this bulb is for you. They cost $50 a pair
shipped. If you are interested please check it out
these links:
http://www.acurainspired.com/gallery...d=780&uuid=112
http://www.acurainspired.com/gallery...id=112&aid=780
hamony_chhon@yahoo.com
these links:
Originally posted by Shiffy
actually i meant, how hard is it to remove the housing.
page 262 of your 2002 3.2TL Owner's Manual.
Just under your fog lights housing there is a small hole
and you need a socket ranch extension to reach the
bolt and unscrew it.
hchhon
LED Fogs
I purchased a set of these and they look freakin HOTTT!!! They are not hard to install at all, just remove one bolt underneath fog light housing and then pop out the whole housing, then you remove your old 9006 bulb and replace it with the new LED one's. Mthutch is correct about not really illuminating the road, but I wanted the look. They are bright as hell with a slightly blue hue to them. I have noticed like another member of this board did as well that people do seem to move out of your way when your behind them. Thanks Mthutch for a great mod...
How about something like this for the 01' + CL??
Stupid question, would you be willing to do something like this for the roadlamps in the CL 01' + CL's?
If not, how did you go about making them for the TL using the 9006 fog lamp bulbs and maybe I can do a little bit of research myself to see if this would work?
What's the wattage, etc.?
Re: How about something like this for the 01' + CL??
quanaman
Jan 9, 2023 07:33 PM
Jul 16, 2017 07:33 AM
