Prepping Trim
Old Jul 21, 2005 | 10:10 AM
soopa's Avatar
The Creator
Prepping Trim
OK, so we got started last night prepping all the trim for re-painting.
Right now, it's a layer of latex over two layers of old enamel (probably lead based) paint.
The latex just peels right off, no problem there, other then it gumming up sand paper.
What about the enamel though? Should I just leave it and prime over it? Should I try to get down to the wood? If so, what should I use? 60 grit sandpaper doesn't seem to be leaving a dent. Scrapers dont work. Heat gun just melts it into the wood.
Old Jul 21, 2005 | 10:24 AM
Scrib's Avatar
Administrator Alumnus
painting it white?
A good primer is all you really need. I don't think it would need to be stripped. Unless it's in really bad shape?
Old Jul 21, 2005 | 10:28 AM
soopa's Avatar
The Creator
well, the latex needs to be stripped because they didnt prep/prime the enamel before painting over it... so the latex literally just falls off the wall. you rub it the wrong way and that shit comes along with you... heh
the enamel, yeah i wasnt sure. only reason i thought to strip, is because all that paint really fills in all the finer details in the moulding, i'd like to have sharp lines again...
Old Jul 21, 2005 | 10:29 AM
wstevens's Avatar
Interesting. Interesting.
you shouldn't need to strip anything. If the trim is rough it may need some sanding, and if it's damaged you may want to use some wood epoxy, but I don't believe you need to sand the current paint off. I just primed my trim and painted. It worked out great for me. If you are using a darker color on the trim, have the paint store tint the primer with the paint color.
edit: I just read your second post and if the enamel wasn't primed and the latex is coming off, then I'd prolly strip it also. Don't try to strip the enamel off also or else you'll still be doing this job months from now.
Old Jul 21, 2005 | 10:34 AM
soopa's Avatar
The Creator
k. cool.
trim will just be painted white, so i just got plain white primer. i don't like painted trim... reminds me of my moms hous.e haha
Old Jul 21, 2005 | 10:40 AM
Scrib's Avatar
yih, ok...
I'd just sand it down, get it nice and smooth and prime.
Old Jul 21, 2005 | 10:43 AM
wstevens's Avatar
Not this this is really related to trim, but if you don't already have a Dremel tool, buy one. It's a great thing to have around when doing home improvements...
Dfreder2's Avatar
Is replacing it with new out of the question? I stained and polyurethaned all of the new, red oak trim in my joint (1,100 sq. ft) along with twelve doors for almost a month straight, but the results are very gratifying.
Painting the walls becomes much easier (and faster) when you don't have to deal with cutting-in around trim. Putting up new trim after painting guarantees you a perfect job.
Old Jul 21, 2005 | 10:46 AM
wstevens's Avatar
This is a good suggestion, and requires at a least a semi-decent saw form cutting 45 degree angles in the trim joints.
Old Jul 21, 2005 | 10:54 AM
wstevens's Avatar
<--------- is going to enjoy this sub-forum by the way.
Old Jul 21, 2005 | 10:56 AM
soopa's Avatar
The Creator
Replacing the trim is definate no-no. One, beyond the layers of paint, it's in really great shape. Two, I'd paint the trim anyway, I don't like the raw wood look on trim being as there is so much wood elsewhere in the house (floors, railings, doors).
Wouldn't be worth it. I'd gain very little for the cost/complexity.
Old Jul 21, 2005 | 11:31 AM
Scrib's Avatar
It's pretty mindless to run tape along the baseboards prior to paint. If you get a couple people you can tape a house in no time.
Old Jul 21, 2005 | 12:45 PM
zeroday's Avatar
more like mind numbing...I had to tape up one of my stairways that's covered with shag burber (sp?) carpeting the other day..what a pain!
Old Jul 28, 2005 | 10:15 PM
mrsteve's Avatar
Not to over run your threads with environmental geek talk but...
Don't sand that paint! The chances of it containing lead based paint are extremely high (90% of homes built before 1950 have lead based paint; 50% of homes from 1950-1978 do as well). Most commonly found on wood trim, windows, and door components. Sanding lead based paint is the best way to introduce lead dust into your home and into your body. It needs to be chemically stripped or replaced if you want to do it the right way.
Old Jul 29, 2005 | 06:42 AM
JLatimer's Avatar
Creepy guy in the mirror.
You can try just roughing up the paint with those 3M pads that work like steel wool, but without the mess. Then prime... I would recommend that you use a Alkyd (oil-base) primer, even if you are going to put latex over top. That will help prevent adhesion problems with the latex over oil-base.
Old Jul 29, 2005 | 12:54 PM
SDCGTSX's Avatar
If it's lead based paint, be careful with sanding. Wear a good dust mask, not the cheapo cup things. Stripping is SERIOUS work on a house. Personally, I'd just scrape the shit out of it and prime and paint over. Most cases it'll look pretty good without having to really dig out.
Old Jul 29, 2005 | 12:59 PM
mrsteve's Avatar
You need more than a good dust mask. You need a negative pressure 1/2 face respirator that is NIOSH approved. Same goes for the respirator canisters. They need to have the P100 NIOSH approval number. Dust masks don't do shit.
Old Jul 29, 2005 | 01:16 PM
supermegaglossy's Avatar
Go Noles!
sand sand, and sand again. if the latex peels off, then whatever you put over it is going to peel too, so get it off. and if there's oil-based paint underneath, then def. use oil paint on top of it.
Old Jul 29, 2005 | 01:32 PM
mrsteve's Avatar
Read the entire thread... it's most likely lead based paint. Don't sand!
Old Jul 29, 2005 | 02:13 PM
SDCGTSX's Avatar
Actually, I'm thinking that some nosey neighbor could report you for code violation. You can get serious fines for asbestos and lead paint violations. at least here in Cali. I still push for scrape, prime, and paint.
Old Jul 29, 2005 | 02:17 PM
mrsteve's Avatar
Not sure about California as I've never done work there. But in New York he should be okay doing the work himself. It's when you hire a contractor to do the work that you start getting roadblocked with red tape.
Old Jul 29, 2005 | 02:54 PM
soopa's Avatar
The Creator
Too late. All been sanded.
Being as there's no furniture, all the floors will be refinished/cleaned, the trim/walls cleaned and painted, and half the house completely gutted... a little bit of lead paint dust is the least of my concerns.
As for legality, yeah, I believe you're right about NY... nobody gives a shit so long as you did the work yourself.
Old Jul 29, 2005 | 03:45 PM
chef chris's Avatar
Homeless
Hmmm...My last house had about 9 million coats of paint on the trim...it was infinitely easier to replace it. At the time I didn't have a good compound miter saw, so I used the square edged molding with the rosettes in the corners...couldn't have been easier since it was only straight cuts. Actually...that type of molding would go extremely well in a house like yours. The rosettes make the molding look more "antiquey", without looking 'old' per say.
Acura604
2G RDX Photograph Gallery
17
Feb 8, 2021 03:32 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
rhdune16
Sep 28, 2015 11:31 AM
