whats the best way to clean engine bay for acura 04 tl?
how dirty is it? if it just has normal dust and such i would spray it down lightly with a hose...then wipe with MF towels. if needed, spray trouble spots with an APC, let sit for a few minutes, then wipe down. finish with a protectant/dressing such as 303.
i took all of the plastic covers off of my TL when cleaning the engine...easier to get at things, etc.
Engine detailing simply implies cleaning the engine compartment and applying protective products to wiring, vinyl and rubber hoses and shields. It's not a difficult task, albeit the first time cleaning is a somewhat messy one. Then after the initial detailing it's just a matter of maintenance.
It's really an easy 45-60 minute task every 2-3 months, the benefits are to increase the resale value of the vehicle and also highlight any leaks that can be rectified prior to becoming a major service repair.
A correctly detailed vehicle looks impeccable, both the exterior and interior of the vehicle, why not extend the same standard to the engine compartment?
Cleaning Methodology:
•Remove any excess debris, leaves and etc from the hood, grille or air-vent openings
•Spray electrical connectors with WD40 which repels moisture / water (avoid spraying on belts)
•Use cling-film or Saran wrap elastic covers to cover any sensors, electrical black boxes, electrical devises that could cause an electrical short-circuits if subjected to water spray.
•This will not guarantee that you won’t cause a problem when cleaning an engine bay but it will greatly reduce the risks.
•Start and run the engine to get it warm, not hot, this will enable the de-greaser to work more efficiently on a warm surface.
•Apply an engine de-greaser (Autoglym Engine Cleaner) or a citrus-based general cleaner (P12S Total Auto Wash) or a solvent free, water based cleaner (Simple Green® Aircraft & Precision Cleaner) http://industrial.simplegreen.com/ind_prod_ext_mor.php by lightly spraying the lower parts of the engine first and then working upwards.
•Enable the cleaner to work by allowing dwell time (but do not allow to completely dry)
•Do not allow the de-greaser to dry or remain on painted surfaces, and be sure to dilute with water before drying with a cloth.
•For heavily soiled areas agitate with a nylon engine cleaning brush and a diluted citrus-based cleaner (P21S® Total Auto Wash)
•When the grease and grime is dissolved and you're ready to remove it, spray with a light (garden type) pressure water hose.
•Use the blower side of a vacuum (avoid area that may be sensitive to a forced air flow) or allow the engine compartment to air dry and then thoroughly wipe down all accessible surfaces and then remove cling-film or aluminium foil.
•When everything is dry apply a vinyl/rubber protectant to hoses, shields and wires, and wipe engine parts with CD2 Engine Detailer or 303 Aerospace Protectarant
•Wipe off any excess with a clean cloth and apply a wax/sealant protection to painted surfaces.
Note- Apply a vinyl dressing to hoses etc (no diethyl silicone fluid based dressings (DS) should be applied in the engine compartment. Use only water based polydimethalsiloxane (PDS) dressings and do not directly spray on to engine parts, spray a cloth and wipe
I've read the tip about covering some things with plastic wrap several times, but not being mechanical, I don't know what those parts would be. Has anyone posted a TL engine photo with the parts to cover clearly visible and/or marked?
Thanks for the post, by the way.
Nitin
Sep 30, 2015 08:22 PM
Mike Bertram
Sep 10, 2015 09:27 AM
