| Welcome to Acurazine.com! |
Thread Tools |
#1 | |||||
Registered User
Installing a custom Navi/Computer System
| Sponsored Links | ||
#2 |
Mega Moderator
All you'd need is a auxillary input adapter. All you need for the headunit would be sound that I can think of..
#3 |
Registered User
Thanks for the reply. But I forgot to mention that I will take the stock headunit off.Late decision. (02 CL-S) I did before however did the thing you said in your post. But this time I will replace the stock headunit/radio with a double-din and I to output sound from soundcard to amp/speakers. I was reading PAC might have a harness kit but don't know which one to get.
#4 | |
Mega Moderator
#5 |
Registered User
how do you take out the whole kit ? where the navi, and radio is?
#6 |
Registered User
btw i ahve o3 tl s fully loaded
#7 |
Mega Moderator
#8 |
Registered User
I trying to say the "PAC OEM-2" unit made by PAC however they make the steering wheel thing also. I kind of figured it out what I am trying to do. I am going to take out the stock headunit and put a double-din lcd at that location. I am not going to be installing any headunit. But I am going to be connecting my carpc to my car speakers using an aftermarket amplifier. I will wired the amp > rca > audio jack of my sound card.
#9 |
Mega Moderator
Why do that instead of buying a sound card with RCA outputs?
I know LOCs work with Amps I'm not sure if they'll carry the audio you'd want becuase that would be a easy solution instead of adding a extra amp if you don't go with a headunit. Worst case buy this $4 part ![]() Last edited by Jonesi; 09-26-2009 at 8:54 AM. |
#10 |
Registered User
yep, exactly. I guess I have to try. I am actually swapping out the stock with aftermarket alpine.
#11 |
Registered User
Any updates?
#12 |
Registered User
Yes, big progress. I 'completely' removed the headunit and no aftermarket install. I am in the process of installing a lilliput lcd + computer in the car. What I purchased is an metra harness kit to output sound. Here are some pictures if anyone interested I can change this thread to my 'worklog' thanks.
This process took about 1.5week (Requires: Molding, sanding, primer, sanding and about six layers of final coat of paint. I keep seeing imperfection so I lightly resand and repaint. Also spraying six layers of paint cost the bezel control port on the right to be stuck and I have to sand it with miniture filer and then another coat of paint.... here are the final pictures for the bezel. ![]() ![]() Last edited by atrix415; 10-30-2009 at 3:53 AM. |
#13 |
Registered User
Did you buy the LCD off their website or somewhere else? Also, what model did you go with?
Where are you going to put the PC in the car? |
#14 |
Registered User
looks good man! more pix!!!!! im planning my install now. im thinking of doing something similar to this..http://www.teamssp.com/jt/images/001.jpg
what front end are you running? |
#15 |
Registered User
Eby701, I am going to put the PC in the trunk with a enclosure 'metal' cage I wrap with subwoofer carpeting matching the truck interior.
#16 | |
Registered User
The other free one is Road Runner, RR. |
#17 |
Registered User
Nice setup with the aftermarket radio. I was thinking of doing that taking out the cigarette socket and tray. I took my radio out completely. This why I have this thread.
#18 | |
Registered User
does the garmin gps interface w/the centrafuse? or is it a standalone app? |
| Tags |
| 7, acura, atrix415, bezel, cl, faq, installation, lilliput, navicomputer, oem2, pac, tl, updates, zine |
| Thread Tools | |
