How to prevent the inevitable seat tear
Member since 1862
I nave an '05 RL with 55k miles. I want to prevent the inevitable drivers seat tear that will occur at approx 150k miles. So I am looking for care that won't make it smell or feel best. I just want what will protect it best. I have read on these posts everything from only use woolite and a damp cloth to use the $60 bottle Leathurette. But the confusing factor is that this is a coated leather (so I read) which means that pretty much all of those care products don't get to the hide anyway?
What really does cause the cracking? Being thinned out from friction and dirt or getting dried out?
Thanks,
Adam
Thanks,
Adam
The most fundamental question to be answered before you clean or care for leather is to establish the type of leather used in the vehicle and / or finish applied (natural, pigmented, vinyl, urethane coated, and etc) as the methodologies are very specific for each type of leather and/or finish applied. Always remember you are dealing with the finished coating on the leather and not with the leather hide itself
The complex tanning process of chromed tanned hides results in the fat liquoring and oils necessary to keep the hide soft and pliable being locked in, the hide is then has a pigmentation coating (a water-based paint) to ensure a uniform colour. By-cast hides are further sealed by a durable polyethylene covering to protect the hide from abrasion from clothing as well as the dust / dirt introduced by the vehicle’s AC system.
Leather Finishes
Leather is a natural product, with a pH of 4.0 and comes from animal (bovine0 hides, which have been chemically processed (tanned) to preserve them. A properly tanned hide (or skin) creates strong, flexible material; resistant to decay. Most leather is tanned cow hide, which are laterally split, rendering an upper (Aniline) and lower cut (By-cast).
The majority (95% + ) of automotive upholstery is by-cast polyurethane covered leather, these leathers have aspects of a natural finish, but more uniform in appearance, by-cast will also stretch more than top grain leather and is therefore subject to show creasing. The upper portion is the top-grain, or Aniline, the lower portion is the split or by-cast. This cutting process creates different faces to the leather. The outside face of the top grain shows the natural grain characteristics, but is otherwise smooth, whereas, the underside appears as unfinished or suede
Myth buster - many leather products market themselves on how they feed leather. In fact your car's leather seats are first coated with a very fine emulsion to give them the desired colour and then a clear coat. So for best longevity you should be keeping that coating as well protected as possible. These same companies would also have you believe you should feed your vehicles polyurathane upholstery or the car's urethane paint finish with protein, collagen, or exotic oils...
Credit TOGWT
Leather Finishes
Credit TOGWT
OCD
Because leatherique Rejuvenator penetrates deep into the actual hide, even on "coated" leather, as it plumps the actual leather fibers, it will release any existing combinations of commercial products that are surface coatings and act to trap dirt, perspiration, and anything else within the coating that commercial products leave behind.
I'll reinterate that all leather that is used as upholstery is surface coated. Even nubuck has a waxed finish and is not totally bare. There is no such thing as a cow with blue or red or burgandy skin. The hides are all a neutral tan color when the hairs are removed, so all colored leathers are coated with a surface that protects the actual hide, as even a grain of sand can wear a hole in the actual hide, and also to give the hide a fashionable finish. Back in horse and buggy days, the hides were coated with a lacquer paint, which they used up until the epa regulated the tanning industry in the 1980s. By 1990 everyone had switched to a water based finish, which Leatherique had been manufacturing since 1960. These finishes are "WATER RESISTANT" which means if you spill your coffee and clean it right away you can clean most of it up. NO FINISH ON LEATHER IS WATER PROOF!!!!! So if you leave your window down or sunroof open during rain, your leather will become drenched and harden. Remember in the olden days that was how they formed leather into armor and shields, by wetting it down and forming it to the warriors body.
The point is that all leather will absorb the proteins and collagens in the Rejuvenator through the finish, and through the stitch holes and migrate laterally and people who tell you leather is sealed are spreading falsehoods. Leather is two stratas, the actual hide which must be kept nourished to maintain tensile strength, luxurious suppleness and prevent the hide from cracking and becoming dry. The top strata is the surface color, which can wear off from normal use. Jeans and cords are like 600 grit sand paper and can wear a hole in your bolsters and arm rests if you don't keep the surface color in tact. Your steering wheel is a great example of how coated leathers can wear. Steering wheels have an extra coating of protective finish on the already finished or coated leather. Perspiration and dirt are absorbed greedily into the dry leather, and combined with the uv rays of the sun a chemical reaction occurs that degrades the hide. All of us have seen this wear on steering wheels.
So, regardless of what commercial surface dressing with it's intoxicating armoas or temporary shine you prefer, you are welcome to use them. Remember they are only a surface dressing that sits on top and traps dirt on the surface and into the pores of the lather. But for the sake of your forgotten hide, you should use Rejuvenator 2 to 3 times per year just to keep the actual foundation of the leather strong and supple. Follow this with Prestine Clean to actually get the hides clean occasionally so they can breathe and last the life of the car.
It makes common sense that if you allow your leather to become dry, it is going to crack, degrade, and you'll be spending thousands to replace it. In a bad economy it is more logical to invest in a quality leather conditioner like Rejuvenator and ph correct clean like Prestine Clean that will actually do something for your hide and for your detailing dollar.
Credit George
Credit George
Thank you TOGWT .. as with everything reading all of the info is helpful ... as was post #13 in that thread.
One of the protectants I liked best was the VW branded one and it was made by Eagle 1 . All I tried seem to add the "slip" factor.
Member since 1862
Great Info
Are "Rejuvinator" and "Pristine Clean" both Leatherique products? Does Zaino make an equivalent? They seem to be much less expensive.
Is it worth buying the kit with all the spoonges/special brushes? Will an old cotton T-shirt do the same thing?
Thanks,
Adam
Thanks,
Adam
OCD
rejuvinator & prestine clean are both by leatherique and need to be used together. I have never used the kit with all the brushes just ordered the bottles separately. Zaino makes a cleaner and a conditioner but like I said I consider leatherique to be like a one a year thing while I use Zaino every few weeks for the smell really (only the conditioner)
Slip is actually a good thing! Ever tried claying without a "slip" factor? Thats what your pants do to your leather when you get in and out. More friction=wear.
Member since 1862
How does Lexol rate as a more regular (3 times a year or something) cleaner conditioner?
It'a at Autozone and $5 for each
I purchased Leatheruqe and plan on using it once a year.
OCD
Lexol is ok but really not that great IMO. Seriously order a bottle of Zaino Leather in a bottle you will not regret it !
http://www.zainostore.com/Merchant2/...duct_Code=Z-10
Member since 1862
Dimples and Indents
o.k I got leatherique and am very very confused.
I let the restorer soak in for half a day and then cleaned it with the prestine clean. So then I noticed something very strange. Dimples and indents on some of the leather.???????? Ideas?????? Very concerned
Did you read all the above posts?
The Old Grey Whistle Test
Leatherique
[Leatherique arose from a need to find a product that would restore the leather in his 1939 Bentley. Nothing he tried was adequate for this special car, so he approached Peck about creating something new. After a lot of work, they produced Leatherique”] Leatherique
This type of top-grain premium leather is mostly used in prestige European automobiles; Aston Martin, Bentley, Ferrari, Jaguar, Lotus, Lexus and Rolls Royce, US Cadillac and high-end German automobiles such as Mercedes-Benz, Daimler AG and BMW. This is the market sector both Leatherique and Connolly were originally formulated
The leather care myth that will not go away... if it’s good enough for a Ferrari or a Rolls Royce it must be good enough for my vehicle. The majority (95% + ) of automotive upholstery is by-cast polyurethane covered leather, these leathers have aspects of a natural finish, but more uniform in appearance, by-cast will also stretch more than top grain leather and is therefore subject to show creasing. The heavier pigments can create much darker colours, protected leather has a substantial finish applied that makes them more resistant to heavy wear and stains.
The heavier pigments and finish do affect the softness and scent, so these leathers often they don't feel or smell like real leather. Just remember you are dealing with the finished (polyurethane) coating on the leather and not with the leather hide itself.
[Leatherique Pristine Clean is part of a two-step leather maintenance system. Step one - Leatherique Rejuvenator Oil is a protein collagen complex that is absorbed into the hide to nourish it, and while it will expel dirt to the surface, it does not harm the dye in any way. This oil nourishes the leather and forces contaminants out of the pores.
Step two - Pristine Clean then removes these contaminants from the surface of the leather and leaves it with a clean, matte sheen. This is the only leather care system that calls for the conditioner to be used first, and it makes perfect sense! The leather absorbs as much of the oil as it can and expels the rest to the surface, along with all the contamination.] Leatherique
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
